I have just acquired a dual carb setup for my 93 Kawasaki 750SS which is currently a single carb arrangement. Hopefully someone can help me here. The jetski oil pump now delivers via a single tube directly into the intake manifold downstream of the carb. When the dual carb manifold is installed, can I still use the same oil pump or is the dual carb pump a different configuration with two discharge lines. Thanks for the help
