2001 virage 1200 looses spark under load ! drive like grandma and it's fine ????
Has been running fine this season but when I try to pull a ski tube I loose spark all three cylinders
It comes back after 25 min. Has anyone had this before????
Re: 2001 virage 1200 looses spark under load ! drive like grandma and it's fine ????
Stator might be heating up under a load. The only thing you can do is test it with an ohm meter when it fails.
