1998 gsx limited-no info gauge
  • 1998 gsx limited-no info gauge
    The info gauge on my GSX Limited went out suddenly. I checked fuses-all good.
    Any ideas? Hidden fuse? Bad gauge?
    Also, lets in water(alot) when afloat and riding.
    Re: 1998 gsx limited-no info gauge
    Did you verify that power was going to the guages? purple wires are power wires.
    If the guage is grounded and has power, but does not register anything, you probably need a new info center guage.
    Find your water leak. Check the obivious places, like the drain plugs, hoses, scoop grate bolts and then look under the driveshaft cover ( while in the water) to see where it is coming into the hull.
    Bill O'Neal <br>
      thanks,will check out tonite.
