I have a 97 GTX that I have rebuilt the carbs on and changed out all the gas lines. On land it sounds like it will run
but put it in the water and it doesn’t get much over an idle. The only thing I didn’t do on the carbs was take out the high and low end adjustment screws. I tried to adjust them to stock but the low end on the PTO side is very tight. Once it turned it was still very hard to turn. Could this be my problem? I am having a hard time finding any material on the adjustment screws other than where they need to be set at.
