buddy of mine is getting a new engine for his 150. he wants to know the best aftermarket mods for this ski and how will they help in handling and overall power. He has 2 2005 ultra150s and he is wondering if he can soup this one up to out perform the others........ Please advise.
2000 ultra 150
2000 ultra 150
Tags: None
Re: 2000 ultra 150
He's already having to put a new engine in one of his 05 Ultra 150's??? Milling the stock heads or buying some aftermarket heads such as ones from ADA or R&D are a good bang for the buck with that engine. I've got an STX-R and by just installing an ADA head with pump gas domes it brought up speed by 2 mph. My 96 XP never increased rpm's like that when I got the heads milled. I'd recommend some sponsons for that Ultra too. They can sure use the extra handling since they are so hairy on top end. I just rode a 70+ mph Ultra this weekend and it was scary. You gotta have some balls to hold one of those wide open over 70.
Re: 2000 ultra 150
Is he looking for just speed? or handling and speed? What kind of budget and what kind of water is he riding in?
If 70 is what you want then I would try these:
Shredmaster Rideplate ($300)
Solas 16/20 Prop Blueprinted & Pump reshimmed and blueprinted
Skiworx Heads ($275)
Skiworx Carb Rejets ($250)
Skiworx Sting Mod ($150)
That will get you to 67-70
If you ride in rough water I would add to that list Beach House Sponsons ($150) and R&D Aquavein Intake ($120)
If you want more speed then you will want to look into Novi 48XR carbs or Flat Tops with full porting or for extream speeds Novi's and Tripple Pipes
I would check out Steve @ www.skiworx.com or James at www.performance-eng.com
My current Setup is, and I see 72-73 everytime:
Novi 48XR carbs
Skiworx Heads 42CC
Ported Cases and Cylinders
Flat Top Wiesco Pistons
Raised ports & shimmed decks
D3 Performance Exaust System
Prok F/A
TDR Waterbox
Skiworx Stinger Mod
Solas 16/20
Tripple Pissers
Tiny Tach
Shredmaster
Modded R&D Aquavein
R&D Sterring Nozzle Re honed
UMI Steering
Shortened Trim Cable
Dual Air IntakesPaul
2001-Level 2 Ultra 150
2002-1100STX DI
2004-15F
2002-30' Baja Outlaw
