Installed a Oil Injector Block-off, Now What?
  • Installed a Oil Injector Block-off, Now What?
    I just installed a block-off but I have a question about the oil lines. Do I leave all the lines where they are or re-route them to the gas tank? I blocked off the 3, 2 small and 1 bigger oil line for the injector. I was thinking about using the oil tank as a back-up gas tank, I would have a valve to let it drain from one to the other, Is that possible? Am I suppose to take the oil tank out?
    Re: Installed a Oil Injector Block-off, Now What?
    Read the tech article on this subject that engine 72o has a rotaray valve and you need oil to lubricate it.
      No you can not use the tank as an extra fuel tank you need to connect the large line back up to the motorit will feed oil to your rotary for lubing
