No, but you might want to put a dab of oil on the o-ring for easy installation.
Starter Install
Use a "silicone" based grease on the o-ring to case bore. Petroleum base sometimes ruins certain rubber compounds.***1100 Venture***<br />OE head mod-- by Riva Yamaha<br />Wiseco (+ .5mm)<br />True-welded crank<br />Riva F/A+ Jet kit<br />Boyeson Power reeds<br />Riva 1100 CDI<br />NGK plugs- BR8HS<br />R&D Aqua-Vein<br />Solas 14-21 Super Camber//Impros<br />Riva rideplate<br />Amsoil "AIO" @ 50:1 pre-mix, currently KLOTZ Ski-Craft<br />MOBIL-1 grease in the pump<br />Sears Diehard<br /><br /> Dream-meter shows 65---- GPS says 54.2 mph best, 9/14/02 @ 850 ft elevation
Help! I put oil on the O ring and was having hard time getting it. Then as I tried to pull it back to adjust one of the two O rings is off its groove and I think is causing it to be stuck and I cant pull the whole starter out. What shall I do, more muscle? and what is to happen to the O ring, can I put it back on if it doesnt tear? I have the O ring from the other starter if if tears, so will this work also? I was hoping to ride it this weekend.
