Hello out there, I am working on a 95 900zxi, finishing the install of the primer kit and happened to notice that the oil pump was loose. I remove the oil pump just to make sure everything was OK with the ccoupler and the mounting bolts,flange, and lines. Upon removing the pump I noticed that the pump had an input shaft like a VRO pump without the marks or flattened side for the arm. Just the shaft was there. Does any one knoe the purpose?? I run the pump with my drill and moving the shaft made no apparent change in oil delivery. Any ideas??
Thanks in advance
James [img]/graemlins/winkanim.gif[/img]
Thanks in advance
