Won't stay running in water.
  • Won't stay running in water.
    Going down to the lake, I get the jetski running on the trailer, then move it in the water, and it dies. It won't start, intell I put it back on the trailer pull it out of the water, prime the engine with fuel through the carburator. Then same thing it dies again when it goes in the water.
    Alot of times if the the ski sits to long it won't start either, then I have to prime the engine again, to start it. Then it starts up right away when ever I want.
    I replaced the engine last summer, rebuilt the carbs this summer, and I can't seem to get it running long enough to break it in.
    Hope to hear from you soon, thanks!
    Take a compression check, check for strong spark, then look to the carbs - it's usually a sign of not having them tuned or built correctly.
