I ordered the "Keihin Personal Watercraft Primer Kit Keihin Triple Carb" from www.parkeryamaha.com . It was $23.95 plus a minimum of $11.99 shipping. OK! What I received was a sandwich size baggie that included the following:
3 ea. plastic hoses (various lengths)
1 ea. pump
3 ea. brass plugs (size not yet determined)
3 ea. "drilled" brass plugs (attachable to plastic hose)
1 ea. plastic "tee"
0 ea. anything else including a drawing or an instruction of how this is done (yes that means ZERO other items).
I'm curious to know if my intuitive feeling that this kit may not be adequate, is correct? Maybe I have all the parts I need but it doesn't seem like it (of course, if I had instructions for a triple carb setup, I'd know) If you are familiar with doing a primer kit on a triple carb ski, could you help me out. Do I need to call Parker, or did I get everything I should have?
I also ordered the carburetor gaskets Parker offered. I bought a single gasket for each carb but when I look in my Service Manual Supplement I see what appears to be a single gasket for one carb and a "double gasket" for the other two. Do I need to go find a single/double gasket set or can I use the three singles?
Thanks,
jim
[ September 16, 2003, 11:04 PM: Message edited by: jaafallon ]
1 ea. pump
1 ea. plastic "tee"
Thanks,
jim
