Hi :
I´ve got the Service Manual.
I´m now verifing the Charging Coil.
I´ve measured the charging coil resistance and it´s within the specified values 1.1 Ohms. Besides there is no connection to ground.
The manual says to verify the charging output voltage between the two brown wires that comes from the magneto with the engine running at 3000 rpm. It should be 20 Vac.
The manual says to disconnect the 3 pin connector.
Then says to temporarily connect the magneto leads except the charging coil leads (brown). This means to connect only the black wire that carries ground ?
