This weekend I'll be replacing the PTO piston in my '95 750 ZXI. The SBT tech I spoke with said I could just replace one piston and she researched my engine and sent me the replacement I will need. The old piston had a little vertical scoring resulting from a loose PTO exhaust stud and loose head bolt. Cylinder walls are fine.
I'm just wondering if there's anything special I should know before starting this project. I have a few questions:
1) Do I use any gasket sealer or similar stuff on the base gasket?
2) Should I use any gasket sealer on the head gasket just in case I have a loose head bolt again?
3) Anything special I should know about putting the rings on the new piston? I've never done this before...
4) I'm assuming the break-in procedure is the same as if I had a new engine, right?
5) To reinstall the cylinder walls, I just use a ring compressor on the pistons one at a time until the walls are over the rings, right?
Thanks!
Thanks!
