Hello, I have a 1999 Tigershark TS770R. I really like the machine because of its stability, handling in rougher water. I have been rather disappointed with its performance, especially in the area of acceleration. I have had a dealer rejet the carbs, which improved the throttle response and eliminated the stalling that was occuring. The boat is pretty weak (as I hear TS770s are) from a standstill and its top speed is an indicated 50-55 mph. I don't care much about the top speed, but I would like to improve the acceleration. Would a new impeller be the answer?? Something else???????? Thanks!!!
TS770R perfromance question
Your best combo for accelleration is to install an aftermarket flame arrestor, make the appropriate adjustments to the carbs, and then re-pitch the impeller at www.impros.com - Dave does great work. Getting your head machined to increase compression is the next step, but you will need to use 91+ octane gas.
