I have a 1999 TS770R and am having a curious problem with it. After a ride I noticed that the bilge pump was on as it sat on the trailer.... It is supposed to run when the motor is running only, unless you depress the bilge button. It runs at very low speed, but if I press the bilge button, it comes on fully and goes off for a few seconds after the button is released. The motor then begins spinning slowly again.. Any ideas?
TS770R electrical problems
It has a switch on the handle bar to run the bilge motor while the engine is off, but the bilge pump is actually designed to run the entire time that the engine is. I replaced the stock bilge pump with an aftermarket (but same manufacturer -Rule) one shortly before this trouble began. U think that the pumpcould just be unsuitable for the application, or would you say that its a switch? Thanks Bryan!
