I need some advice on best way to remove the drive shaft on 1996 Monte Carlo 770. I need to replace the floating shaft seals and bearing. Have already removed the impeller and stator (came off as one assembly) and can see the splined rear end of driveshaft sticking out the back. The front end of the driveshaft goes into a 3" diameter coupling on the engine, but doesn't want to come out. I have tried to pull it directly out - no luck. I have tried to unscrew the shaft CCW - but won't budge.
How does this remove???? What tools needed?
Is a grease fitting needed to lube this bearing?
Also, my original problem was boat filling with water (from bad shaft seal). I couldn't get speed up above a crawl even with engine racing. Is this to be expected with a hull full of water?
