Can someone please help me. I need to know what size gauge wire the Tigershark has on the wire for the bilge pump. The specific wire I
am refering to is the red wire that holds the
fuse for the pump. I don't have access to the
ski right now and I want to purchase the wire
ahead of time. If no one knows, will the wire have the size printed on the outside of it?
If your curious, my bilge pump remains on
even when the engine isn't running or the
key isn't in. There is no water on the inside
either. I read some where on line that it's
most likely a problem with the bad rectifier.
A new rectifier -- if one could be found-- is
about $280. So, I was just going to add my
own switch that disconnects the power to
pump when not in use. For the time being
we have just been removing the fuse.
Thanks in advance for any help,
-- Dave
-- Dave
