Results 1 to 2 of 2
    Sep 2002
    Arkansas
    235
    Post
    Ok-After my 2nd. rebuild on this motor, (#3 piston blew apart-#2 lost a chunk off the top also.) I noticed on the assembley process there are little plastic plugs on the intake manifolds for vaccum hoses or something, and on the #3 intake, the "plastic plug" was broken due to age I suppose. Would this along with failure to properly bleed the oil-injection cause a MAJOR lean condition enough to cause the damage? Plus, I found a repair on the bottom-side of the crankcase that was performed by a welding shop that appeared to be leaking. A little JB Weld should do wonders there.
    What do the pro's think?
    and no I dont want to pull it and spend $1500.00 for a SBT rebuild.
    Jim
    Feb 2001
    Clearwater, FL
    7,358
    Post
    Sorry, JB Weld will NOT fix a case reliably.
    Yes, if your caps for the carb sync tubes are missing you will have a major air leak. They are commonly broken off during insertion to the hull if you don't pay attention.
  1. Replies: 1
    Last Post: 04-04-2006, 05:19 PM
  2. Replies: 16
    Last Post: 07-05-2005, 01:41 PM
  3. TigerShark Monte carlo 1000 triple
    By kingtut210 in forum Tigershark
    Last Post: 01-05-2005, 11:00 PM
  4. Tigershark Monte Carlo 1000 - Water :(
    By redr2 in forum Tigershark
    Last Post: 09-28-2004, 09:30 AM
  5. 97 tigershark monte carlo 1000
    By Speakrdude in forum Tigershark
    Last Post: 09-25-2002, 08:58 AM
