I have searched through the documents on here and learned much, but nothing seems to address my problem.
I have just started working on this TS about a week ago. The block was rebuilt last year, but I am not sure if the carbs were also rebuilt. They don't look it, but I don't know for sure.
My problem is when I crank it up out of water, it will idle for 5-10 minutes fine, then just rev so high that it shuts itself off for no reason. If I start it up again, and give it full throttle, it will rev up then die. The rpm's go beyond the 8000 on the tach, so I am not sure if this is normal. Should there be some kind of rev limiter on this pwc?
Anyways, I thought maybe its the carbs, but why would they just start revving for no reason? I didn't see any of the butterflys sticking.
Any suggestions would be greatly appreciated.
Patrick
Patrick
