Results 1 to 3 of 3
    Jul 2003
    New Zealand
    20
    Post
    There is a water hose that comes out of the engine just above the drive shaft, it is blocked off & I am wondering what it is for, can I put a permanent hose connection on it for flushing the engine after salt water use?
    21,545
    Post
    You should have a clamp and a rubber cap there - that is where you can attatch your flush kit.
    Jul 2003
    New Zealand
    20
    Post
    It does have a short piece of hose sticking out & a stainless bolt stuck into the end of it with a clamp holding it all togeather, I havn't got a flush kit & just poke the hose into the exterior water outlet (by the gas filler) to flush the engine, is this good or do I need a flush kit?
  1. Sea Doo GTX 787 water hose question
    By HC1949 in forum Sea-Doo
    Last Post: 07-05-2007, 05:16 PM
  2. 95 Raider 700 Water Box Bad???
    By bmclaws in forum Yamaha
    Last Post: 08-22-2005, 08:01 PM
  3. Daytona 770 Bearing Replacement
    By Kip in forum Tigershark
    Last Post: 06-12-2002, 10:31 AM
  4. HELp !!!! water in cylinders - confused
    By Airborne in forum Yamaha
    Last Post: 01-29-2002, 10:16 AM
