Tech 11 - Operation of a Carb
  • Tech 11 - Operation of a Carb
    This tip explains to you what an carburator is and how it works.
    8.6 MB High-res (Cable, DSL, T1+): click here
    .7 MB Low-res (Dial-up modem): click here
    [ February 08, 2003, 05:20 PM: Message edited by: Technical Support ]
    Thanks for the two videos on carbs they were great. Because of your videos I realize that the rebuild kit I have purchase in the past from a supplier in the houston area was missing the high speed check valve piece wondering if that might be causing my acceleration problem. Keep up the great work you guys have got going on!
      It's possible...they need to be in perfect condition - no creses or tears and be perfectly sealed to the pump body.
