Tech 22 - Alligator Point
  • Tech 22 - Alligator Point
    This segment is an introduction to our new Engine Test Facility, tag named Alligator Point. We have setup stationary test docks to run OEM and our engines 24/7 in, efforts to further improve our engine's durability and performance over OEM.
    8.6 MB High-res (Cable, DSL, T1+)
    .7 MB Low-res (Dial-up modem)
    What brand of watercraft was the most reliable. And what brand performed with a stock motor clostest to an sbt motor.
    A buyer looking for input [img]/graemlins/winkanim.gif[/img]
    Josh
      That is information we are not willing to divulge at this time, sorry.
        leave manufacture out. which motor last the longest.
        <a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
          Sorry, test data for the most part is trade secret - we didn't spend all this money to help the competition [img]smile.gif[/img]
            i have 2 sbtmotors inquiring mines want to know no test data has to be transfered. just oem or sbt
              Oooooh, sorry I misunderstood what you meant. We have yet to find an SBT motor that does not last as long as the OEM counterpart.
                Cool thats good news for me
                  Yall must spend a lot of money on gas [img]tongue.gif[/img]
                    Understatement of the year!!
                      On average what's needed first in testing, carb rebuilds or new motors? Do you feel that this is consistent with real world use?
                      When testing in that manner you're likely to rule out water injestion and other preventable issues. Unless there are design weaknesses overheating and other similar problems shouldn't be an issue either. With that in mind, what are the typical failures that you find with these machines?
                      • #12
                        We will not share specifics, again, trade secret. Carb rebuilds are definitely not an issue, and yes we have eliminated virtually all external testing issues and are able to simply wear the engine itself out.
                        • #13
                          I understand the protection of trade secrets. In another way of asking, how does a motor wear out in your controlled tests? Does it just seize all of a sudden, or start to run weak and loose power? Again, I am not asking for trade secrets, I am just wondering when a motor is declared worn out.
                          • #14
                            Most of the time they run and eventually loose power after many hours of wide open throttle. We run them until they stop, besides the regular refueling/oil breaks.
                            • #15
                              How long does it take for you to seize a motor. Any motor?
