Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Feb 2001
    Clearwater, FL
    7,373
    Post
    If you are going to store your craft for a couple months or more, you need to winterize. The purpose of this is to make sure the internal parts of the engine do not start to rust, and to make sure the fuel in the ski does not start to break-down and oxidize.
    The first thing is to add stabilizer to the fuel. You can get fuel stabilizer at any marine or auto supply store, just mix it in the ratio according to the back of the bottle, and top off the tank with the stabilized fuel. After you add the stabilizer to the fuel tank, then you have to run the stabilized fuel through the lines and the carbs, you can do that when you flush the engine or on the last ski trip you make, just make sure you have run it enough to pump the stabilized fuel through the carbs.
    The next thing you should do is flush the engine as you do after each ride, except you will fog the motor just before blowing out the excess water. Connect the flush kit, start the engine, turn on the water. Let the craft run for about 5 minutes at idle to flush out the cooling system.
    See this video for flush procedures: http://server1.sbtontheweb.com/forum...ad.php?t=12000
    To fog the ski, you need a can of Fogging Oil, available at nearly any dealer or auto parts store for a buck or two. It's basically foaming oil in a spray can that you can inject into the air intake or directly through the carbs, to coat the engine internally with a thick layer of protective oil. Spray down each carb for 30 seconds.
    Some skis will have little plugs on the airbox over the carbs, that you can remove for access. Some skis such as the Yamaha powervalve 1200's have no access, and you are not able to fog the motor properly, you must pour a heavy amount of oil down the plug holes and bump the motor over several times to distribute it as best you can. After fogging is complete, put 1oz of two-stroke oil into each spark plug hole and bump the motor over a few times.
    After you finish the fogging procedure, shut off the hose water, blip the throttle a couple times and shut the motor off.
    Contributed by Dank - "You do have to drain the exhaust pipe on the 770's. Depending on the year the drain will be located in different spots. But look under the rear of the pipe and there will be a 10mm fitting that you remove and the pipe will drain out all the water."
    Lubricate all the ski's grease fittings and cables. You need to have a grease gun and a cable luber comes in very handy. There are several grease points on a craft, usually on the drive train (pto, pump, drive shaft holder).
    When all the lubing is complete, then you should remove the battery and place it on a maintenance charge. We recommend a Battery Tender. You can buy a battery tender at motorcycle shops, or several places online. Do not use a trickle charger; if left on too long it could overcharge the battery. A Battery Tender is a special charger that you can leave the battery hooked up to indefinitely. Maintain the battery's electrolyte levels with distilled water.
    If you have a Sea-Doo you also need to change your pump oil once a year, when you winterize for storage. See this thread for instructions:
    http://server1.sbtontheweb.com/forum...ead.php?t=4088
    Now that all the internal work is done the only thing left to do is wash and cover your craft.
    Attached are the Sea-Doo factory procedures:
    Attached Files Attached Files
    Sep 2004
    Ocean City, New Jersey
    3
    Default Re: Winterization Instructions
    Thank You for providing this information.
    Great site!!!
    Aug 2004
    Charlotte, NC
    117
    If you get a rebuilt motor from you guys, can you just leave it alone over the winter? Instead of doing break-in now and winterizing, could I just leave it alone until next spring? Or should I just go ahead and break it in and winterize?
    21,552
    If you do not run it, you will not have to winterize. THe very best thing would be to leave it bagged.
    Aug 2004
    North of TDot Ontario
    27
    How do I flush the ski, and then fog it? If it does not have anything to cool it how can I run the motor for a min or more to fog it? and this would be out of the water of course so that it would not pump any more water though it. Its -30 Deg here in the winter and I don't want a cracked block.
    mike
    21,552
    You fog while still running hose water through it.
    Aug 2004
    Olean NY
    30
    There is no need to run antifreeze thru the engine? I have heard running the antifreeze thru the engine will displace the pooled water in lines and nothing will freeze?
  8. #8
    21,552
    Only Sea-Doo's cooling design has large pockets to trap standing water. In colder climates Sea-Doo's do need some anti-freeze.
  9. #9
    Jul 2001
    GA.
    55
    I was told by a guy that has a 2 stroke outboard boat and motor that he runs his motor dry of fuel so he does not have to worry about stabilization and old fuel when he winterizes. He felt the same could be done to my Polaris jet ski and I could leave the tank empty. Is this true?
  10. #10
    21,552
    On small bore low HP engines, that is true. On PWCs is a really great way to lean seize or burn holes through pistons.
  1. Winterization, Fogging, and Antifreeze ???
    By lee_leses in forum Yamaha
    Last Post: 11-17-2005, 08:00 AM
  2. 750sx winterization, grease points
    By TomG in forum Kawasaki
    Last Post: 08-01-2005, 12:03 PM
  3. I lost printed instructions to pull motor
    By walt z in forum Yamaha
    Last Post: 06-06-2005, 10:55 AM
  4. Replies: 1
    Last Post: 10-02-2004, 07:29 PM
  5. carb kit instructions???
    By jandrew in forum Sea-Doo
    Last Post: 06-30-2003, 10:11 AM
