Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Aug 2004
    Virginia
    56
    Talking Re: Winterization Instructions
    Just an FYI For winterization I run antifreeze through the motor. I have an old fire extinguisher that I cleaned out, I then fill it with antifreeze and presurize it with my air compressor.
    1.) add stablizer to fuel.
    2.) flush the system hooked to the hose (running on stabilized fuel)
    3.) open air cleaner and spray fogging oil into the carbs until the motor blows heavy smoke and dies.
    4.) replace air cleaner
    5.) remove spark plugs spray fogging oil 30 sec each cyl. repalce plugs turn motor over but do not start.
    6.) Use a shop vac to get all water out of hull.
    7.) remove clear water line from exaust port on rear of ski (Sea Doo) place the line over the fire extinguisher and energize the system with antifreeze until you see it come through the clear exit tubes on the pipe and head. (usually takes about 1/4 - 1/2 gallon)
    8.) place a bucket at the rear of the ski.
    9.) replace the hose on the exaust port. (the extra antifreeze will now drain out of the exaust port into the bucket)
    10.) change the pump oil and wash the ski.
    11.) remove the seat and remove the water with a shop vac again from inside the hull.
    12.) place a 1x2 across the hull under the seat to prop it open just a hair, Install cover and put it away.
  2. #12
    Feb 2004
    New Port Richey Florida
    50
    Default Re: Winterization Instructions
    So you should not run the gas all the way out of the carbs? You should just put stabilizer in?
  3. #13
    Aug 2004
    Hampton Roads Virginia
    44
    Correct.
    Fill the tank and add StaBil. Make sure you run the ski enough that the StaBil is in the carbs.
  4. #14
    Apr 2003
    Sicklerville/somers point
    171
    how would you winterize a 2000 gp1200r ?????
  5. #15
    21,555
    Exactly as the article already states.
  6. #16
    Jun 2004
    Ks
    111
    Is antifreeze necessary on my 98 1100 ZXi? This is the first year with my skis and I'm in a freezing climate and a little worried about taking care of them (93 XP, 98 ZXi) properly.
  7. #17
    21,555
    Only some Sea-Doo's require it in some climates.
  8. #18
    Jan 2004
    Big River CA
    43
    I know the fuel stabilizor brand name but is there a brand name for the fogging oil or spray. Thanks
  9. #19
    21,555
    Gold Eagle is popular - every auto store, Wal-Mart, K-Mart - whatever - has them.
  10. #20
    Jan 2004
    Big River CA
    43
    Thanks.
  1. Winterization, Fogging, and Antifreeze ???
    By lee_leses in forum Yamaha
    Last Post: 11-17-2005, 09:00 AM
  2. 750sx winterization, grease points
    By TomG in forum Kawasaki
    Last Post: 08-01-2005, 01:03 PM
  3. I lost printed instructions to pull motor
    By walt z in forum Yamaha
    Last Post: 06-06-2005, 11:55 AM
  4. Replies: 1
    Last Post: 10-02-2004, 08:29 PM
  5. carb kit instructions???
    By jandrew in forum Sea-Doo
    Last Post: 06-30-2003, 11:11 AM
