Results 1 to 9 of 9
    21,555
    Post
    For the Do-it-yourselfers out there, here's how to change your own oil!
    You will need the following:
    Oil suction pump, vaccuum canister type reccomended
    E12 Torx bit socket
    Metric sockets (optional)
    Ratchet
    3L Sea-Doo 5W-40 Mineral oil for SC, 10W-40 for NA
    New Oil Filter
    New oil filter canister cover and bolt o-rings (optional)
    Make sure the craft is level. Start the engine and let it idle for 30 seconds.
    OPTIONAL
    Unsnap the cooling reserve tank from the seat brace, then remove the four bolts securing the seat brace to the hull. Set it and the air duct attached to it, off to the side.
    Next, use a small tube with your oil pump (we used Sea-Doo RAVE valve lines) and feed it down the dipstick tube. Remove the oil fill cap and suck out all the oil you can get, which will be 3L.
    Next, use an E12 torx socket to loosen the oil filter cap located right behind the engine. Pull the bolt straight up and gently wiggle the cap off with it. The cap may be difficult to remove, you can pry gently with a screwdriver between the canister and cover if you need to. Remove the old filter and replace it with a new filter. If the o-ring on the center bolt or the o-ring on the cover is damaged, replace them also. Lubricate the o-rings with engine oil and be sure to center the filter and cover while installing, making sure the o-ring lines up with the step on the filter.
    Refill the oil system with 3L of Sea-Doo oil and replace the dipstick. Replace the seat bracket and coolant reserve tank.
ID:	14   Click image for larger version.
ID:	15   Click image for larger version.
ID:	16   Click image for larger version.
    Aug 2004
    Hampton Roads Virginia
    44
    Default Re: Oil Change, Sea-Doo 4-TEC
    I just changed the oil in my 04 GTX for the 1st time. I recently bought the 2003 SeaDoo PWC Tech Manual CD on EBay but set out with just the SBT Tech Article. Apparently there have been some changes.
    1. E-10 Torx Bit socket fits the oil filter cap bolt (not E-12)
    2. I did not follow (or look at) the below procedure for allowing maximum oil draining. Next time I will try.
    3. Count on breaking the oil filter cap O ring. I had to pry the cap off (gently) and you will break this O ring (My thief of a dealer, Casey Cycle City charges $4 for this 15 cent O ring and $12 for the filter).
    4. The SeaDoo replacement oil filter (part number 420956741) has the "Champion" brand name on it, S 147 18 : 03 RBX - X 347
    5. The Oil filter I removed has the ROTAX brand on it S 339 11 : 33 RB-X336
    6. You will encounter 3 O rings all together during the filter change. The other 2 will probably rarely need replacing.
    7. Due to message size limit, I will follow up with info from the 2003 Manual
    Dave Z
    21,555
    Thank you for the updates - our guide was written from a 2003 unit.
    Aug 2004
    44
    Default Re: Oil Change, Sea-Doo 4-TEC 2 0f
    Attached is a Doc with info from the 2003 Tech Manual
    Attached Files Attached Files
    Jan 2004
    Brisbane, Australia
    12
    Are you able to give the SeaDoo part numbers of the 3 o'rings you require or better still, the standard o'ring dimensions/part numbers. Can you advise what shop you bought the service cd-rom from.? Also a source for the vacuum pump would be handy.Thanks
    Colin
    Dec 2003
    malta
    18
    Question Re: Oil Change, Sea-Doo 4-TEC
    on the manual it says 10w-40 for the sc,which is correct ?
    thanks
    21,555
    If your temps are 90+ use 5w. Either will work just fine though.
  8. #8
    Jul 2001
    Oradell, New Jersey
    16
    Can we get some clarification on where exeactly the o-rings go on the oil filter cap, since I'll be changing mine this weekend. My dealer gave me two large rings where one of them is very thin. Txs Gary
  9. #9
    Apr 2005
    Metro Detroit
    11
    Quote Originally Posted by dzuskin
    The front of the engine must be tilted down approximately 15 degrees to facilitate the removal of the oil. Raise the rear of the watercraft accordingly.
    2004 4-tec SC sea doo shop manual cd
    Do search on ebay for shop manual.
    regards,
  1. 96 sea doo xp oil block off question
    By harsha in forum Sea-Doo
    Last Post: 10-01-2005, 08:42 PM
  2. 94 Sea Doo spi oil pump block off
    By khall79 in forum Sea-Doo
    Last Post: 05-29-2005, 11:13 PM
  3. 1995 sea doo xp without oil injection
    By hightest55 in forum Sea-Doo
    Last Post: 06-28-2004, 12:46 PM
  4. Sea Doo oil
    By Joe in forum Sea-Doo
    Last Post: 06-30-2001, 05:51 PM
