I have had this jetski since "92" , have had a number of problems with it! Starting with the engine not running hot enough to burn fuel. So they recalled it and added a thermostat and platinum spark plugs because it ran to rich and fouled them out! After repeated starting of machine, starter had to be replaced because of the hard starting. ($520.00) In"95" had middle cylinder rebuilt , no compression. Cost me $756.00 (Still have low hrs. on engine). My question is:
Took it out this summer first time in years!
used a little either and it started right up, went through a full tank of gas then it stalled right away. Turned dial to reserve started it again, took off! But it only had 50% of its power to plain out. thought it just need more gas, well added 2 gallons. that didnt work now im clueless to why?
Please dont tell me that the cylinder dont have compression because i ran it to reserve! Ive went thru this before and a few summers of it being held up in the shop for repair !@##!@#
Now here I am again with same old problem, yes this has happened before with power failure.
Please give me some good news for the first time that I have owned this thing?
