Rotary Valve Timing
  • Rotary Valve Timing
    Can anyone tell me what the correct rotary valve timing should be on a 1993 657 Sea Doo ? I've been reading the forums and getting a little confused, 130 or 147.....
    I'm using a 159 degree rotary valve.....
    Thanks,
    Skooter
    Re: Rotary Valve Timing
    No 657 uses a 159 valve or is timed to 147. What is your year and model? There is an article in the tech section with allt he specs.
      It's a 1993 XP 657...not 657X
        147 valve timed to 130.
          I have a 159 degree valve !!!???
            Will a 159 valve work on this engine ? (93 657 XP)
            If it will work what do I time it to? The posts above are a little confusing.... one says 130 and another recommends 147... Help !
            Thanks,
            Skooter
              Nope. I gave you the correct specs. Get the correct valve and set it..
                WAIT A MINUTE..... YOU GAVE ME TWO DIFFENT ANSWERS in two different posts. Which reply do you want me to refer to? A little more explaination would be greatly appreciated...
                Thanks,
                Skooter
                  I gave you one answer, you are not understanding it.
                  Do you understand that there is a cutout size of the valve, and a timing spec - and they are two different things? You need a 147 cutout valve - the valve has an open section of 147 deg. And you set the timing to 130.
