98 TS 770 exhaust connector?
  • 98 TS 770 exhaust connector?
    Hi all, On my TS 770, there is a black rubber boot that connects the tuned pipe to the water box. Well it split in two and the machine ran really bad. I ran electrical tape around it and it ran great! Until it split some more. Can someone explain why this happens and where I would be able to locate one? Thanks!! jason
    Re: 98 TS 770 exhaust connector?
    You can not tape it up with electrical tape. It will not hold the heat and pressure for long.
    You will have to order one from an Arctic Cat dealer or an Online source loke
    Rouges jet sk's or brownsliesureworld.com
      I have the same problem with the same jet. Did you solve your problem just by buying the original exhaust hose ? Do you have a resonator on yours ?
      :emoticonc
