Hello, I have a 1986 X2 that originally came with a 28mm carb. I switched it with a 38mm carb and had a couple questions.
1.) The motor seems to run a lot hotter. Would any aftermarket exhaust allow more water to flow and cool the motor quicker?
2.) I tried richening up the high speed adjuster screw to see if that would keep the ski from running too hot, but the adjuster screw on this carb isn't functioning like I'm used to. You can turn it clock-wise as much as you want and it NEVER SEATS! Is this a common thing and I just don't know about it?!
I appreciate all your suggestions. Thanks!
