Results 1 to 3 of 3
    Jun 2004
    Rockmart, GA
    34
    Exclamation '95 SLT 750 Impeller replacement
    Well a piece of the leading edge of my impeller almost the size of a business card got spit out the back of my boat Saturday afternoon.
    What does the wisdom of the group have to say about impeller replacement? What else should I check/replace while I'm at it? Don't hold back I want to know everything, including whether I should install a 4* wedge while I'm at it.
    BTW, I just installed an OP ride plate and I LIKE it. :)
    TIA for your comments and advice.
    Zipper<br />'95 Polaris SLT 750<br />Rockmart, GA
    Jul 2004
    CHICAGO
    72
    Default Re: '95 SLT 750 Impeller replacement
    The 4 degree wedge would help you top speed especially on the SLT cause it has no trim adjustment. And as for your prop I would recomend a Skat-trak swirl for your best all around performance
    Jun 2004
    Rockmart, GA
    34
    Thumbs up Re: '95 SLT 750 Impeller replacement
    Quote Originally Posted by SUCKMYWAKE
    The 4 degree wedge would help your top speed especially on the SLT cause it has no trim adjustment. And as for your prop I would recomend a Skat-trak swirl for your best all around performance
    Thanks for the recommendations. It turned out that my stator wasn't in very good shape in addition to the hosed impeller. :( While I'm in there I'm going to replace the impeller (with a Skat-trak), impeller spacer, stator, seals, bearings and o-rings. That should put the entire pump in top shape mechanically. I'm also going to add the 4* wedge to get that extra top end. Top speed right (20 minutes) before the impeller failure was 46.2 mph according to my gps. If I crack 50 mph after the repairs I'll be very happy. :D I know that just renewing the stator and impeller is going to give me some improvement for sure.
    Thanks again,
  1. 750 impeller problems
    By Redryder in forum Kawasaki
    Last Post: 10-06-2005, 04:06 PM
  2. Replies: 2
    Last Post: 08-29-2005, 08:43 AM
  3. 1995 slt 750 & 1996 slt 780
    By la90043 in forum Polaris
    Last Post: 07-29-2005, 09:24 PM
  4. 750 ZXI high performance impeller shaft
    By jsp in forum Kawasaki
    Last Post: 07-20-2004, 10:35 PM
  5. polaris 750 slt reed replacement
    By claborne in forum Polaris
    Last Post: 07-26-2001, 02:45 PM
