1993 GTX High speed miss
  • 1993 GTX High speed miss
    I have put kits in the carbs., the lows are set at 1 1/4 and highs are 0, new plugs, sniped the plugs wires, compression is good. It cranks and idles good, it will rev up but when it gets above about 5000 it has a constance high speed miss. Any help?
    Re: 1993 GTX High speed miss
    sounds like you need a wear ring and or a impellar , the high speed miss is the rev limiter . what kind of carb kits did you use ?
