When I pulled the pump there was no sign of a neoprene seal between the pump and the pump support plate. The wear ring spun in the pump and wore into the support plate. I thought the spinning wear ring destroyed the neoprene seal. My Sea Doo shop manual shows a neoprene seal between the pump and the pump suport for the GTX Limited. The parts breakdown does not show a seal or sealant. My Sea Doo dealer said his parts book did not show a seal. He said they come without a seal from the factory and if they start to leak they run a bead of RTV between the pump and support plate. Can anybody tell me what should be used for the seal, or what they found when they took theirs apart.
Thanks,
Bruce
Thanks,
Bruce
