Why does my regulator have 3 washers under the spring? I do not see them on the parts manual. Also, is it possible to test it while attached to the hose and not in the water?
Water Regulator?
Re: Water Regulator?
No you can't test on the hose. Someone may have snipped the spring too short - replace it to be sure.SBT Tech Support is here to help with your problems.
My 97 GSX also has 3 washers under the spring this was a Seadoo upgrade in 1997. So it is normal to have those 3 washers there.
Later ChrisFactory Pipe Spec 2 <br />愛&D Rec Head<br />意ovi 44XR Carburetors<br />FLY Flame Arrestors<br />感rimer Kit/Premix (40/1)<br />愛+D Aquavein Intake <br />Galindo Grips<br />愛+D 85/88 mm Hydro-force Nozzle<br />惹olas XO (16.5/24) Impeller<br />媲each House Sponsons<br />廈ydro-Turf Mats<br />嫂WD Bow Spray Deflector<br />廉armin Etrex GPS (61.5 MPH)
