Results 1 to 4 of 4
    May 2001
    odessa, FL
    75
    Default 94 750 Super Sport XI Exhaust Leak
    Any suggestion on Exhaust Leak Problem. I can't seem to stop the leak at the muffler on top of the engine I replace the GASKET, EXHAUST MANIFOLD, the Rubber Tube and it still leaking slowly, is there any solution to this problem? any help will be appreciated.
    21,552
    Default Re: 94 750 Super Sport XI Exhaust Leak
    Take the pipe and manifold to a machine shop and have the surfaces lapped.
    May 2001
    odessa, FL
    75
    What’s a surface lapped? Is there a machine shop in the area you recommend?
    Jun 2004
    Spring Hill, Fl.
    149
    Thumbs up Re: 94 750 Super Sport XI Exhaust Leak
    You can also try a product called Marine Tex. It is a two part epoxy that is similar, but WAY, WAY better than JB Weld. I have filled stipped out threads in aluminum block, drilled, and re-tapped: They are still holding after three years-- so I highly reccomend the stuff. Although I am personally boycotting them, (they support those bastards at the BWN) I know West Marine carries it. Any other marina should too. Apply and sand down. Alot cheaper than a machine shop. Rob
    P.s. Where is it leaking exactly? Between the flex joint and the intermidiate pipe? or the flex joint and expansion chamber? Have the exact same ski and may have some spare exhaust parts for sale. Have to check my storage unit first.
    ride it like you stole it
  1. 750 SSXI Exhaust Leak?
    By Jax in forum Kawasaki
    Last Post: 05-21-2006, 06:38 PM
  2. 96 750 Super Sport XI Intake Grate?
    By JPSmall007 in forum Kawasaki
    Last Post: 02-16-2004, 03:03 PM
  3. LA-1995 Kawasaki 750 Super sport XI Jet Ski
    By Clyde W. in forum PWC's For Sale
    Last Post: 08-07-2003, 11:58 PM
  4. 94 XP EXHAUST LEAK
    By bonne76 in forum Sea-Doo
    Last Post: 06-09-2003, 10:46 AM
  5. 1994 Kawasaki 750 Super Sport XI
    By porsch964 in forum PWC's For Sale
    Last Post: 09-04-2001, 02:46 PM
