What Is The Bext Way To Prime It? Caz Right Now It Is Bone Dry.
1997 1100 Triple Wave Venture
Re: 1997 1100 Triple Wave Venture
Do You Mean Your Tank Is Dry? If So Fill Your Tank. Disconnect The Fuel Line At Carbs And Use A Primer Bulb Like On A Outboard Motor Fuel Line To Prime. You Can Get Them At Walmart For $7.00. Unless You Want To Suck. (i Dont Recommend That). Then Choke And Start As Normal.WATERCRAFT SERVICES. PROVIDING THE RESIDENTS OF HOUSTON AND SURROUNDING AREAS WITH QUALITY WORK ON THEIR PWC AT A FAIR PRICE.
