Results 1 to 3 of 3
    Aug 2004
    Massachusetts
    4
    Default 97 challenger (787) carb settings
    While I'm waiting for my carb rebuild kits to come in I'm going to see if adjusting has any effect on the issue that I'm seeing. I've read about 40 topics on it but still not sure about a couple of things.
    When adjusting the low speed setting, I start with the pto carb, then move to the mag carb. I'm going to back out each screw 1 turn then fire up the engine (service manual says 1 turn, boards say 1 1/4). Once the pto is adjusted what do I do with the mag low setting, is this set to match the pto setting?
    Should the idle be in the ballpark before doing the low setting?
    There's some conflict on the high, some sources say 0 turns for both, some say 1/4 for pto and 0 for mag.
    Is it safe to spray some carb cleaner in the carbs while the engine is at idle?
    When in neutral and go to wot, should the engine be nice and smooth or sputtering and sounding crappy?
    Thanks,
    Hoog
    Nov 2003
    Glendora, CA
    6,846
    Default Re: 97 challenger (787) carb settings
    Read the answers to you questions below,
    No, open both the same. If the oem SD manual says 1 turn out from closed, then set both at 1 turn out from closed. You cannot tune one carb at a time on a two carbbed boat. Set the idle to 3000 out of the water and 1500 rpm in the water ( or close to that so it idles smooth and not too fast).
    Yes.
    If you have the manual, see where it says to put them.
    That is NEVER SAFE.
    No, it should not sputter and sound crappy, ever.
    Thanks,
    Hoog[/QUOTE]
    Aug 2004
    Massachusetts
    4
    Smile Re: 97 challenger (787) carb settings
    Hi Bill thanks for the comments. I never made it to the carb settings tonight, that'll be tomorrow's chore. Tonight I cleaned the rave valves, they were filthy,lot's of carbon build up. I believed the dealer when they told me they cleaned them so always took it out of the equation.
    I only had some carb cleaner and 220 grit sandpaper. Sanded off as much carbon as possible and gave them a little soak in some carb cleaner. Put it all back to together and I couldn't believe the difference. Engine started right up, throttle was very responsive, no stumbling at 3k rpms, throttle for the most part moved easily and the engine was responsive. Engine even sounded different, much moire fluid, like it wasn't struggling at all. Had a couple of brief moments where there was no response but not nearly as bad as before. I can tell that the dealer was definately messing with the carbs to compensate when they found that the boat was running so bad. I can smell gas now when idling and think that they set the carbs very rich to compensate. I'll post tomorrow and let everyone know the results after I adjust the carbs.
    Thanks again for the help.
    Hoog
  1. 787 carb help
    By howardtp2000 in forum Sea-Doo
    Last Post: 10-25-2007, 07:03 PM
  2. Carb Settings on a new SBT 1200N-PV Motor
    By dtd696 in forum Yamaha
    Last Post: 08-11-2007, 07:11 PM
  3. Carb settings
    By piersbc in forum Sea-Doo
    Last Post: 05-23-2006, 03:48 PM
  4. fuel pump exchange/ carb settings
    By 02_GSXR_600 in forum Polaris
    Last Post: 08-08-2005, 12:14 PM
  5. 580 White carb settings
    By VaSuperjet in forum Sea-Doo
    Last Post: 07-24-2005, 09:27 PM
