Results 1 to 6 of 6
    Jun 2004
    Corpus Christi
    18
    Red face Exhaust has water leak
    On my 97 Stock Superjet thier is a minor water leak right above the manifold on the stock exhaust pipe.I have no idea how a hole would end up thier.When I flush I can see water coming out a little faster than dripping speed.
    Should I ignore this problem since the amount of water is not much?
    Whould riding it cause more water to flow out or flushing it with the water hose?
    To me flushing it would force more water through the hole because water is being forced through. I could be wrong about that.
    Any ideas on how to fix it without spending money at a welding shop?
    21,545
    Default Re: Exhaust has water leak
    Do not run it like that. Your hose is not putting out 50 psi - your cooling system is. It will get worse and you can easily suck up any spray into your motor.
    Get it welded - probably around $30.
    Jul 2004
    Indiana
    87
    You could use a jb weld type product but I would listen to the good guys above me. You are probably hanging out in salt water so keep that engine compartment sprayed down with wd40 and flush that ski.
    Jun 2004
    Corpus Christi
    18
    Thumbs up Re: Exhaust has water leak
    I found a used pipe here in Corpus Christi, Tx for $45.00.It came off a 99 Superjet. The welder told me thier were other hair line cracks that would probably get worse so I decided to find another used one.It wasn't the salt that caused this problem. When we put the new SBT motor in we used never seeze on the exhaust bolts instead of lock tight. All that banging around when the pipe became loose damaged it.
    thanks for the advise
    Jul 2003
    Corpus Christi, Tx
    86
    ADrider, where at in Corpus? I'm out here in Calallen, do you go to the Nueces River or Lake Mathis?
    Dec 2006
    Corpus Christi, Tx
    6
    know of a good seadoo repair place in corpus anyone? someone that won't screw me over??
  1. Preseason check list!!
    By jcar25 in forum Sea-Doo
    Last Post: 08-22-2021, 04:49 PM
  2. 95 Raider 700 Water Box Bad???
    By bmclaws in forum Yamaha
    Last Post: 08-22-2005, 07:01 PM
  3. Water Leak on Exhaust on 96 XP
    By Mark Henderson in forum Sea-Doo
    Last Post: 06-30-2005, 06:00 PM
  4. water leak
    By 98gsxl in forum Sea-Doo
    Last Post: 05-03-2005, 10:02 AM
  5. 97xp will leak water after shutting down.
    By pasha in forum Sea-Doo
    Last Post: 07-10-2003, 09:30 AM
