Results 1 to 4 of 4
    Jun 2004
    Pickwick Lake Area
    120
    Default 94 XP - Strange noise
    I recently replaced the shaft and PTO. The first time out after about an hour of riding I heard a high pitched noise and felt a decrease in thrust. Sort of felt like a slipping transmission. I was making hard turns when I heard it. I stopped the ski and checked inside and underneath for blockage. Found nothing. I started the ski and it continued the same noise with little thrust. I shut if off again and was preparing to tow it. Curiosity took over and I restarted it again and it ran fine. Actually ran great and no more noise for the rest of the weekend. Yesterday I was doing some more hard turns and I heard the same noise and felt the same loss of thrust for about 3 seconds. It continued to run okay the rest of the day. The only thing in common on both occurrences was that the grate was partially out of the water while turning and the ski was at WOT. Could the ski have injested some debris and chewed it up? Would sudden loss of water to the intake cause the noise? The only thing that hasn't been thoroughly gone over on the ski is the pump. Would a worn wear ring cause this? :(
    Jun 2004
    Glendora California
    812
    Default Re: 94 XP - Strange noise
    [QUOTE= The only thing in common on both occurrences was that the grate was partially out of the water while turning and the ski was at WOT.
    BINGO !
    Jul 2004
    Oregon
    220
    [QUOTE=Bill O'Neal1][QUOTE= The only thing in common on both occurrences was that the grate was partially out of the water while turning and the ski was at WOT.
    BINGO ![/QUOTE]
    Yeah, when I turn mine hard on WOT and I managed to hydroplane a 360, it makes the *worst* squeal. Makes you think you're going to blow something up. But mine still runs, so I still do it.
    Jun 2004
    Pickwick Lake Area
    120
    Thanks for the reply. I'm just a little cautious since the shaft and PTO repairs. The sound is similiar to when they went out. I've been checking the motor mounts and greasing regularly since then. :)
  1. Strange Engine Starter Noise 96 XP
    By Webster627 in forum Sea-Doo
    Last Post: 01-18-2006, 07:09 PM
  2. Replies: 14
    Last Post: 10-19-2005, 01:18 AM
  3. 01 Seadoo XP Engine Noise
    By gifer in forum Sea-Doo
    Last Post: 08-14-2004, 12:08 PM
  4. 750 ZXI - Whirring Noise
    By cbeastwood in forum Kawasaki
    Last Post: 07-23-2003, 03:52 PM
  5. Strange (new) noise
    By tommyadrian5 in forum Sea-Doo
    Last Post: 06-02-2003, 11:33 AM
