If your 800 or 951 is backfiring when you try to start it, make sure you haven't mis-aligned the magneto cup on the flywheel. See this thread for details.
SD 800 and 951 Magneto Cup alignment
Last edited by Technical Support; 08-13-2004, 07:06 PM.SBT Tech Support is here to help with your problems.
Please do not use Private Messaging for Tech Support, use the forums.Tags: None
