Got my Warranty Replacement engine put in back in Feb,
This is a 657x being out in a 94 SeaDoo GTX.
I Had some Huge Squish Measurement problems with the engine. The ski would do 10 or 15MPH at WOT.
After emailing with you several times about the squish being way bigger than what I thought it should have, you said it was "within specs".
So I took it to the local Dealer and they had to cut the squish down and then put the engine back together. Problem solved, it ran great for 4 months and goes 42 MPH GPS, which is what the old engine did.
Now this week I went to start it, the engine will not turn over, the cylinders are filling with oil.
Not sure which it is, but I don't know what could be causing this. When I called my dealer, he said it was most likely a bad Crank seal. I took the spark plugs out and turned it over, the oil came shooting out. After that it stated with a new set of plugs in there, but oil is coming out the back of the ski where the exhaust comes out. The ski is smoking like a BoyScout Campfire.
Let me know if you can help, having some problems with this engine it seems
