For Tech Support
The instuctions for installing the Genesis exhaust manifold says to torque it to 40 ft lbs. At 30 I sheared off one bolt then tried another and sheared it off as well. Do bolts wear out and get weaker? I'll have to remove the engine and take it to a machine shop and have the bolts drilled out. Can I use just regular bolts from the hardware store that match?
Also I have a broken bolt in the manifold (the one that holds the exhaust pipe to the manifold). There is a wire that goes from the manifold to the electrical box. I goes into the manifold inside a piece of rubber. I need to remove it to get the manifold totally off to take it to the shop. Do I just pry the rubber stopper looking thing out with a screwdriver? I cannot find that part on the polaris diagrams so I dont know what the wire is for.
