'00 ZXI 1100 losing RPMs and bogging
  • '00 ZXI 1100 losing RPMs and bogging
    I have a 1100 ZXI and I am having troubles with it. It will take off fine and get to about 6900 RPMs but then the RPMs drop and the speed drops. Also when going wide open and then slowing down and turning around, it bogs way down and sometimes bogs when I take off. What could be the problem with my jet ski losing RPMs and bogging? I was thinking maybe carbs, or something like a fuel vent or something creating a vacuum in the tank and maybe not giving enough fuel. Anyone have any ideas? PLMK, I want to get this thing back out on the water!
    Re: '00 ZXI 1100 losing RPMs and bogging
    Here is how I would go about it. Pressure test the Gas tank, check the compression in the cylinders. If all checks out good, has to be in the fuel, and most likely in the carbs. Give them a rebuild and you will probably solve the problem.
