Re: Zx1000
you should not have to cut anything. I just installed one of these on a 99 stx about 2 weeks ago. If you havent already removed the carbs it is really the only way to do it. You must inspect the rod that holds the butterflys on. When you look closely you will see some "C" clamps that hold the bar on, inbetween each carb. Get some small needle nose pliers and remove them, when you remove these clamps it will be easy to remove the bar. Once you get the bar removed make sure that you install the plugs inside the holes. They can be a pain in the you know what to get in so they may need a little lube and elbow grease. I hope this helped, post again if you have any ?'s.
