(97-99) Stock GP1200 Topspeed?
  • (97-99) Stock GP1200 Topspeed?
    Hi, i was wondering if anyone on here has GPSed a stock GP1200's topspeed?..if so, please let me know the results and post them here
    thanks a lot
    Re: (97-99) Stock GP1200 Topspeed?
    Stock Is 61-62 At Sea Level With Good Air And Smooth Water. With Radar.
      That's 2-3 more than I or my buddies ever saw.
        so Technical Support, youd say stock speeds shoudl average from 58-60mph on GPS? Thats what i figured
        thanks
          Air Temp,humidity And Water Condition All Factor In To An Engines Performance.also Rider Weight And Trim Angle With Increase Or Decrease Mph. Im Going By An Adverage At Our Location. I Have Heard People Say Their Stock Gp Will Run 64-65 On Radar. Thats Pushin It A Bit. I Cretainly Have Never Seen A Stocker Do That In Any Condition. 58-60 May Be Right For Your Conditions. Anyway You Look At It Around 60 Is A Good # To Go By.
            How much does fresh or salt water change the top speed or MPG?
              I have not done back to back tests but I believe salt usually adds about 1MPH as the skis ride a bit higher up. MPG? Nada.
                I Get 61 Usaly Salty
                  GPS, radar or speedometer?
                    I think both the answers are correct.the hulls from 97-99 differ greatly,in 97 you wouldnt get the same results on 10 skis ,as the hull got stiffer in the next years the numbers were more constant.
                      My '99, when stock, did 60.2 the only time I checked it on a borrowed GPS. Elevation 1034' and glass water at 7:00 in the morning. '98's and '99's are a little faster than the '97's due to the 5 degree pump nozzel
                        You're right - the 5 deg nozzle was good for 1-2 MPH over a stock '97.
                          Would i be able to switch my stock nozzle on my 1997 GP1200 to a 98 or 99 5 Degree Pump Nozzle?? and gain 1-2mph?
                          thanks a lot
                            Yes
                            • #15
                              Yes you can. I think I still have one for sale if you're interested - $50.
