Results 1 to 2 of 2
    Sep 2004
    1
    Default running problems
    Can anybody help?? I have a 2001 Superjet - it will run flat out but won't run slowly (at 1/4 throttle). I have just fitted a Protec Mach 1 Exhaust, could this be the reason why? Also, which jet is which on the carburettor (stock carbs). Thanks.
    Apr 2004
    HUMBLE /ATASCOCITA TX
    762
    Default Re: running problems
    If You Install An Aftermarket Exhaust You Must Also Modify The Carburator. Pop Off Psi And Jetting Changes Are Required With This Type Of Modification. It Will Never Run Correctly Until These Changes Are Made. You Can Even Do Damage To The Engine If Ran Like This. Im Not Familiar With This Particular Pipe So Contact Pro Tec And Get The Recommended Jetting Changes For Your Application.
  1. 1998 Tigershark TS640L Running Problems
    By 91seadoosp in forum Tigershark
    Last Post: 07-08-2007, 08:56 AM
  2. 97 XP running problems
    By zephyr in forum Sea-Doo
    Last Post: 06-12-2006, 11:18 PM
  3. Running problems
    By patti3336 in forum Kawasaki
    Last Post: 08-10-2005, 06:15 PM
  4. Replies: 2
    Last Post: 06-06-2005, 10:40 PM
  5. 1999 XL 760 starting, running problems
    By Millertime in forum Yamaha
    Last Post: 06-18-2002, 11:25 AM
