Can Anyone Tell Me Which Wires To Test With Ohm Meter , Or If You Could Give A Diagram And Spec Ranges For Testing The Stator. I Think Its My Problem For No Spark.
Testing Stator On 97' Gp 1200
Re: Testing Stator On 97' Gp 1200
Dan, open up the electrical box, the larger of the two connectors (white) that has 4 terminals, you need to check each one to the black terminal on that same plug connector. They are white/red, white/black, and white/green. According to my manual they each should read approx 248-372 ohms. This checks the Pulser Coil, you need to check the Charge Coil like I said in my other post. Also. make sure your ground points are clean and secure (where all your black terminals attach). Anything else, let me know
