Hey, I got your package that has the loctite, tube of gasket sealant, and the bottle of gasket stuff. I was told that everything I needed to put an engine together was in the package. Which do I use to seal the bottom end?
Your loctite/sealant package
Re: Your loctite/sealant package
Everything is in there do do 'a swap' not build a block. You need Threebond 1211 for case sealer - any auto store caries it.SBT Tech Support is here to help with your problems.
