problem with coil #2
  • problem with coil #2
    I noticed that on the ski that there was no spark on cyl # 2. I hooked up an electrical meter and was getting no voltage after the coil, but I was getting voltage before the coil. So I ordered a new coil to replace the old one. My question is, when I pulled the coil off of the spark plug wire I noticed that there was some sort of glue holding the wire in the coil, it is on all three coils. Do I need to put glue back on the wire to hold it in, or should I leave it alone and not put any glue. If I do need glue what kind should I use? I know that epoxy and super glue will probably eat away the plastic of the coil. Any help is appreciated.
    Re: problem with coil #2
    I don't think you need to, if it starts coming off then yes. Are you sure it wasn't some type of grease?
    Paul
    2001-Level 2 Ultra 150
    2002-1100STX DI
    2004-15F
    2002-30' Baja Outlaw
      no, I dont think that it was grease. It looked like it was superglue, it appeared to be clear. I will not put any in and wait to see if anything happens. Thanks
        this may be some type of silicone.... is it rubbery????
          Silicone ignition grease is clear. It's also not a bad idea, seeing as how it might get wet.
