I've got a used 89 Waverunner 500 and a 96 Waveraider 700. I have located what seem to be the flush connections on the engines but I'd like a 2nd opinion or 3 before I actually buy the hardware and hook everything up. I already removed the screws and both screws are identical. Pictures of the screw holes are shown below.
The first image shows the Waverunner 500 engine from a few feet away with an arrow pointing to the screw hole. The 2nd image is a closeup. This one seems fairly obvious since the word WASH is right next to it.
The 3rd image is the Waveraider 700 engine from a few feet away with an arrow pointing to the screw hole. The 4th image is a closeup with a red arrow pointing to the screw hole and a green arrow pointing to what I believe is the water connection to the head, which you can see connects via a hose to just below the screw hole. That make this seem obvious as well, but like I said, I want to make sure.
What's hard for me to believe is that you can get enough water through any fitting that will fit a hole that small to cool the engine. I mean, the hole itself is only about 1/4" in diameter. Any fitting going into that hole is going to use some of that for the wall of the fitting, so you're left with a hole that at most would be about 3/16". Can that really be big enough?
Thanks.
Thanks.
