I have a 1993 GTX with a white 587 engine. Will the 657 engine interchange? From reviewing part numbers, it appears that the external size and engine bed are the size, so it might slip right in?
Interchangeable engines?
Re: Interchangeable engines?
Yes, it will physically fit just fine, BUT, to get it to run properly you will probably need to swap the electrics from the 657 also. You also may need the exhaust system for the 657. If you are not installing a complete motor there may also be issues with the rotary valve and carberation.Any technology, sufficiently advanced, will appear as magic.
