650 only running on 2 cylinders
  • #31
    Re: 650 only running on 2 cylinders
    It is a good idea after you assemble the carb to connect the pop off gauge to the fuel inlet, block the return and pump up to 15psi. It should hold this pressure with no problem. If it leaks then you have a bad needel or misadjusted arm/diaphram problem.
    I also use it to check the fuel pump diaphram to make sure it hold 10psi for sevaral min.
    • #32
      I ran into the same problem with sbt's carb rebuild kits.... diaphrams were way to stiff compared to the oem diaphrams. They caused problems with the engine being flooded with fuel and oil. Also, I ended up getting new springs directly from a polaris dealer.... 7 bux a piece but better than taking the whole thing apart again.....
      • #33
        We have not had that issue with the SBN kits for over a year. Every part is now 100% oem spec.
        • #34
          I agree. Every kit I have got this year has worked great in any SBN carb.
          • #35
            hmmm...maybe I got one of the older kits, because they were way different than the Mikuni ones. All I did was pull the SBT diaphragms and put in the Mikunis' to fix my problem. Curious.
            Got Wake!
            • #36
              did it have a red or siver button on the diaphram? silver are the old ones.
              • #37
                glad to hear that sbt supposedly fixed the problem with the carb kits. too bad its too late for me lol. I have had nothing but good experiences with them for the engine and the service though!
